Може да теглите както видео така и аудиофайлове.
Много настройки на приложението.
Резолюция на видеофайловете- HD or SD
Теглите неограничени по големина файлове.
http://www.multiupload.com/777LKL8HY9
VERSION:
v 1.4* Fixed a bunch of minor bugs
* Updated caching to be a lot more efficient and faster
* Overall speed enhancements especially in the Download Manager while downloading.
* Fixed some bugs with the 'Show URL' feature
* Removed rare crash the occurred when downloading videos (mostly VEVO videos)
* Added full support for URL schemes in requests (which means that for example 'Share by mail' will work and open the mail app)
* Make sure to tell all your friends about ProTube!
Thanks for all the feedback!
http://www.mediafire.com/?6v0eevjh3r9nsblVERSION:
v 1.5.1
* Fixed some bugs I and made improvements
* Updated caching to be more efficient and faster
* Download Manager less buggy while downloading and updates more frequently while downloading, removed selection problems.
* Coming soon: Translations (German, French and maybe other languages. Contact me if you can be so kind to translate the english strings into your language, I will do german, french is already done)
* Spread the word and tell everybody you know about ProTube
v 1.2.1
* Updated images
* Fixed some bugs
* Added polish translation
http://www.mirrorcreator.com/files/0L38R3ON/v 1.5.3
* Fixed some bugs
* New background image for the option bar
Неkaloqnz написа:ProTube 1.5.3 Тази версия може ли да се импортират файловете които са изтеглени в ipd? Защото аз съм с тая 1.3 там нещо си не става....
При мен не се получава. Не ги виждам. Трябва явно някакъв .png файл ръчно да слагам към всеки клип.cezare написа:1.var/mobile/Librаry/Pro Tube
2.Да можеш.
