Четене и отговаряне на SMS-и от всякакви места на вашия iPhone с IOS 5+ като изскачащ прозорец без прекъсване или затваряне на приложението в която се намирате!
Приложението е за iOS 5 + !!DESCRIPTION:
Requires iOS 5 or higher
Another spectacular tweak from the DrComputerIT "Awesome" serie.
With AQM you can:
1. Read and reply SMSs from any places on your iPhone with an iOS-like popup without switching or closing the app you are in!
2. Open a Quick Compose popup to send your SMSs quickly from everywhere (remember to setup the activator gesture for this! This feature support another DrComputerIT app, "VMK+Groups" to send SMS to a group if people very quickly!);
3. Both Quick Reply and Quick Compose are customizable (background and textfield color, text color).
Note1: settings icon will be added to SpringBoard
Note2: this tweak as been tested only with Latin characters (oriental languages may have some unknown issues).
Note3: if you experience any bug, just report it from its settings app!
remember iMessages are not supported at the present moment.
Special Note: This tweak has been tested on many devices without any issue. If you are experiencing problems like crashes, the must be due to incompatibilities with other tweaks. As we cannot test every, just mail us about the incompatible tweak and we will try (try) to make them work together.
Thank you all for the warm welcome for this tweak!
See larger Screenshots below
VERSION:
v 1.0-17
1) Fixed an issue with preferences not being saved;
2) New HD images;
3) Now you can close "Quick compose" swiping your finger up on the textfield;
1.0-17
ЦЪК
