Thundergod
ckeuta
Регистриран на: 21 Дек 2009, 12:54
Thundergod
Мнение от ckeuta »
Ever imagined you’re in a middle of a crumbling thunder? Or in a rain forest and relax to the crisp smooth sound of the water falls and rivers. In short, if you want to experience nature at its best ambience at the comfort of your home or where ever you want, then grab this app for iPhone and iPod touch. The Thundergod.
With a good set of microphone, you can enjoy the sound of nature like you’ve never experienced before. Not only thunder, you can listen to 5 other environments and set your mind off transporting you to an almost holographic place. The longer you listen to it, the more you’ll be convinced that you are in a different place with realistic sounds.
The sounds are not just repeating loops like other sound effects have. The Thundergod environments are like long concerts, or musical plays that have beginning, middle, and conclusion. Choose on different ambience depending on your mood. If you like stimulating sound, try the ‘Thor’ but if you want to be relaxed, you can choose from different sonic environments.
If you think you’ll have the same quality of sound when you play it with speakers, well it can sound good but not as compelling as with the earbuds or earphone.
The initial price for this app is at $9.99, not cheap but really worth the price regarding it has earned great impressions from different forums and reviews. If you want, you can try the free intro app. And if you think you want more of the Thundergod, then go and realize that the price will sound good to you. Anyway, the best way to explain it is for you to experience it.
